Spl comparisson. Pdx vs hifonics
Uh, what ohm load will you be running them at?
At 4 ohms, the Alpine would be your choice since it is rated to give you 1,000 watts RMS @ 2 or 4 ohms. The Hifonics is only rated to give 850 and in real life you should expect 700 watts out of the Hifonics @ 4 ohms.
At 2 ohms, the Alpine is rated to give you 1,000 watts RMS and I believe the Hifonics is rated to deliver 1700 watts RMS. Although the Hifonics is overrated, it should still produce close to 1,500 watts RMS @ 2 ohms. In a perfect world, doubling the power would give you 3 decibels of SPL, so in theory you "should" be 1.5 decibels louder with 50% more power. In real life it doesn't always work out that well since you have electrical load, physical limitations of your speakers, and so on.....
Of course, 1 ohm is a no brainer.... Go Hifonics because I think the Alpine isn't rated to run at 1 ohm!
You are welcome //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
As much as I like to bash Hifonics, I will say that it is affordable and it will do the job that you want it to do;)
jblw12gti
jblw12gti
papillion, NE
Annnarbor84
