Speedwire/9wire
The 9 wire goes from amp to behind the radio so you don't have to run new wire
You connect the crossover in the door and run wire in your door for the mid and tweeter
The 9 wire goes from amp to behind the radio so you don't have to run new wireYou connect the crossover in the door and run wire in your door for the mid and tweeter
I'm sorry. I not exactly sure what you're saying about running wire in the door.
nothing should change if you wire the 9 wire conductor properly. just in case you're wondering, the 9th wire is best used for the remote turn on for an amp.
when you starting getting into active set ups is when you worry about modifying the 9 wire, and even then you dont really modify it. you just need to run an extra 2 conductor wire to each tweeter and put the midrange speaker on the original 9 wire.
Nate154
Nate154
Des Moines, IA
wew lad
