Pistonsfan70
Well after getting all of the info possible on the new Brahma 10", I have decided to go with a XXX 10"
Here is what I've gotten so far (from dealers and Adire)
Brahma 10 Dual 2 Ohm Brahma 10 Dual 4 Ohm
Fs 21 Hz 23 Hz
Qes 0.37 0.43
Qms 10.3 9.9
Qts 0.35 0.42
Vas 39.7 liters 39.7 liters
Re 2 x 1.4 Ohms 2 x 2.8 Ohms
Le 2 x 0.5 mH 2 x 0.8 mH
BL 12.8 N/A 16.0 N/A
Xmax1 28.5mm 28.5mm
Sd 286 cm2 286 cm2
SPL2 82.2 dB 82.3 dB
Pmax3 600W 600W
MSRP 389.00 389.00
And here is an e-mail from Adire about the sub..
Thanks for the e-mail! The depth of the Brahma 10 is 7"; you'd want at
least 7.5" internal depth to allow for breathing through the pole vent.
For power handling, 1200W is over the rated power handling of the
Brahma; I'd recommend acquiring a Brahma 10D4, and parallel the voice
coils for a 2 Ohm load. In a 0.5 cubic foot sealed box, you will reach
full excursion below 30 Hz with 600W of power. More power won't get you
more output, since you're at the limits of the driver.
Thanks again,
Adire Tech Support
Sorry if this post is dumb but I hope someone finds this info useful
Fs 21 Hz 23 Hz
Qes 0.37 0.43
Qms 10.3 9.9
Qts 0.35 0.42
Xmax1 28.5mm 28.5mm
Sd 286 cm2 286 cm2
Pmax3 600W 600W
MSRP 389.00 389.00
Thanks again,
Adire Tech Support
