SOUNDz
when at a stopped position with brake pedal pressed ex: [ sitting at red light, etc....] the head unit lights dim a lot to the bass of the music or whatever. but when i pull off, it pretty much goes away. btw, hu max vol. 30, i usually play at 20, sometimes 22. could this mean the alt is getting weak, a bad ground, or even the factory speaker wire could be dark/ slightly burned out, or maybe too small a gauge? i have no amp on speakers btw. i plan to, and i want to upgrade speaker wire to at least 16g. i wonder if the speaker wire is too small, that if you put too much power through it, that it will burn out. i heard that is the case with power wire. T or F?
