Soundstream Lil Wonder 4.620 BNIB
79bronco
Soundstream LW 4.620. Same amp as the Rubi 4.600
Was going to use it for my new build, but found a 5 channel on another forum, literally the day after I bought the SS amp. I have never hooked it up, only removed from box to take pictures.
Ordered it on amazon as a refurb with a 2 year warranty. There is nothing mechanically or cosmetically wrong. 10/10 for both.
LIL WONDER III AMPLIFIER
RMS power @ 4ohm: 80 watts x 4
RMS power @ 2 ohm: 155 watts x 4
RMS power @ 4ohm Bridged: 310 watts x 2
LED power and protection indicator
High and low level input
Selectable X-over: HPF/Full/LPF w BPF capability
Continuously-variable low pass crossover: 50Hz-4KHz
Continuously-variable high pass: 15Hz-500Hz
Bass boost: 0dB / +6dB / +12dB
Soft turn-on circuit
2 ohm Stable stereo operation
Mosfet pulse width modulated power supply
Increased efficiency by 10-15%
Higher S/N ratio due to new circuit optimization
Lower THD due to modernized circuitry
Higher damping factors for better drive control
Improved crossover filters
Upgraded output transistors for improved reliability
Better ground isolation for less noise
Increased protection to reduce speaker damage
Dimension (mm): 390 x 52 x 205
85+ shipping
65 shipped and ill take it... here's your lowball if you want it gone //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
79bronco
79bronco
United States
79bronco
