Sony Xplod 1000w 2 Channel
dcnorth
So I've had this amp for about 6 months and it has run my 2 12 inch infinity kappa perfects perfectly.
The other day I went for a drive and stopped at the gas station. I was not playing music loudly, I was with my girlfriend who hates loud music, so there is no way the amp got hot. I came back out and tried turning the music up a little bit and there was nothing but stock bass.
The amp is in power protection mode.
When I turn the car on it is green for about 5 seconds and the subs will push out, then the light goes red and everything stops. I have power going into the amp just fine, the remote start is also fine. It is well grounded, I've unhooked and rehooked the whole system numerous times.
No matter what I do I still get the red power protection. There amp is not pushing power out to my subs when the red light turns on, but when the green light is on for a few seconds it does.
Is my amp faulty?
Help?
-Dcnorth
Is my amp faulty?
Help?
-Dcnorth
Check the subs itself to see what the ohm load is. Also unhook the speakers and turn the amp on again. if that does not work it might be a bad transistor sending the amp into protect. But #1 get rid of sony its garbage.
dcnorth
dcnorth
Michigan
Bigmann6374
