WILL TAKE OFFERS
Sony Mobile ES XS-TL1 w/ Built in Amp
BUT IT NOW PRICE
$85 Shipped
On eBay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=019&sspagename=STRK%3AMESE%3AIT&viewitem=&item=290113737080&rd=1&rd=1
SPECS
63/4" Aluminum Cone Driver w/Rubber Surround
1 ohm Voicecoil Matched to Digital Amp
Compact Vent-loaded Enclosure only 16" High
Vertical or Horizontal Mount Bracket Supplied
Preamp and High Level (speaker) Inputs
High Efficiency Class D PWM Amplifier
50W x 1Ch at 1 ohm
Adjustable 50-180Hz Lo-Pass Filter
Adjustable 50Hz EQ (0 to +10dB)
Adjustable Output Level & Phase
Speaker Section
Speaker Type
Impedance
Circuit System
Inputs
Outputs
Maximum Outputs
Rated Outputs
Input Level Adj. Range
Cut-off Frequency
Low Boost
Power Requirements
Current Drain
Frequency Response
Mass
Supplied Accessories
Woofer
16 cm (61/2"), Aluminum cone type
1 ohm
PWM (pulse width modulation) circuit
RCA pin jacks; high level input cords
RCA pin jacks (pass-through)
100 W
50 W (1% THD)
0.2 - 2.0 V (RCA pin)
0.8 - 8.0 V (High level input)
50 - 140 Hz
0 - 10 dB (50 Hz)
12 V DC car battery (negative ground)
At rated output: 5A
35 Hz - 200 Hz
Approx. 3.6 kg (16 lb. 15 oz.)
Parts for installation and connections (1 set)
Height: 405 mm (approx 1515/16 in)
Width (Diameter): 200 mm (approx 77/8 in)
