Sold Sony Mobile ES XM7527
JayRich
1. Product: Sony Mobile ES XM7527
2. Specs:
* 150 watts x 2 or 360 watts x 1 into 1 ohm
* non-negative feedback design for superior reproduction
* high-voltage/high-current modes
* single-ended push/pull design for stability at 1 and 0.5 ohm
* discrete differential inputs for reduced noise
* regulated input power supply
* MOSFET output power supply
* high current MOSFET finals
* continuously variable high-pass/low-pass crossover (50-400 Hz, 12 dB/octave)
* selectable low-cut (subsonic filter) 7Hz-40 Hz with selectable cut and boost (0-10 dB)
* 103 dB signal to noise ratio
* 3-way protection circuits
* 30-amp fuse
* heavy-duty connectors with brushed aluminum cover panel
* 12-11/16"W x 3-5/16"H x 12"D
3. Description/Condition: 7.0/10 Missing Cover plate and a set screw
4. Price: $150 +shipping OBO
5. Pictures:
This is SONY mobile ES amp in perfect working order. It is not the best cosmetically only in that the cover plate is not included and a set screw is missing but if you will be running it bridged it wont matter. Im asking $150+shipping for the amp. Woofersetc.com has it for $299 Buy it now (7527 SONY XPLOD AMP 2CH SUBWOOFER 360W AMPLIFIER .5 OHM - eBay (item 130418384697 end time Oct-05-10 13:58:44 PDT)) so I figure half that is fair for a perfectly working SQ amp
JayRich
JayRich
Richmond, VA
kr15
