It's Infinity Reference coaxials for rear fill off the HU, Hertz HSK 165s in front off a bridged EA4200 for 140 watts per side. Head unit is an Alpine 9886. Before when all my speakers were amped I had crossover controls front and rear and just started off with a gain attenuation on the rears to get the proper mix.
When I switched to running the rears off the head unit I realized I took away the amp crossovers from the infinitys and they were now running full range and distorting while the rest of the system had more to give. My head unit only high passes all four speakers at the same time as low as 80HZ. The only option to keep the rear fill playing cleanly at full volume was to use the head unit's 80HZ high pass but I believe my Hertzes are still capable of staying clean at around 70.
I know the first thing alot of people will chime in with is 'get rid of rear fill.' Im considering it but don't quite want to do it yet.
For those running rear fill off a head unit without a very flexible high pass and amped fronts, do you run your rears full range? Cross them over separately? How? Running active or some other way? Tryin to figure out the best most cost-effective way to keep the infinity reference coaxes at about or 90 HZ but take the Hertz HSKs down to about 70 at the same time.
