Some new toys (10,000 watts)
PSturmer
well i got a bunch of stuff today. 4 hifonics bxi2607d's. 1 max-link. a hunk of copper, .5'' by 1.5'' by 36''. the amps will be ran at 1/2 ohm
1/2 ohm they take fine. i actually sold that set in a local build so these are all new. at .25 ohms they shut off but put out a ton of power. daily i will run 1 amp at 1 ohm to 2 subs. for comps (including drive by and bassrace) i will have all 4 amps at .5 ohms.
at 1/2 ohm and my voltage drop they'll put out around 2k
I've seen a couple with properly set gains get dangerously hot running at 1ohm.
i use hifonics in mostly all my installs i do. i always run full grounds. never had a problem with heating up. at 1 ohm they get "warm" maybe 80-90 degrees on a day thats 70 outside
PSturmer
PSturmer
Minnesota
PSturmer
