solo x, sa and dd
  • 5
Hello....I've recently received a gift from my sister....and now I'm thinking of upgrading my amp and sub....I know what amp ill get me, but I'm struggling to chose between a kicker solo x 12", SA z v4 12" and DD(there's many options in my country on dd)....I'm thinking of the 9512i....I assume these are good subs, pricey but good....I want to put it in a custom ported box, but ill consider a sealed box too....what sub will give the most output while sounding good? Kickers aren't really that good compared to the other two I mentioned, right?...ill only consider buying one of the subs, so I won't have to worry much about space
the zv4 and dd9512 are both going.to be.really good drivers ..it just depends on what ur wanting ..ditch the sealed idea.to get optimal output from either ...but i think the zv4 is.the more well rounded sub ...what amp will u be using ? also what is ur electrical like?
Planning on getting 2 kicker zx2500.1's or a good enough sundown amp.....I've heard people hype about the kicker warhorse amps, what is the actual rating on the warhorse? Is it powerful enough?....ill be running a high output alternator with a high cycle(optima) battery...
You'll need more than an optima battery for 5,000 watts. And I would go with a Tantric SHD for that kind of power.
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Watch the video pop put up. Those don't put up anywhere near what they claim. Hence why spokey said run it at 1 ohm.
faeezhio
faeezhio
cape town, SA
IonRL205
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
