Soldering Oznium led's?
Mr.meyhem
I got a bunch of super bright leds from oznium (6 3mm, 20 5mm, and 2 10mm, plus 28 of the 1/4 watt 470 ohm resistors) so i understand you solder the resistor to the positive side of the light. id have to run the positive to a switch or something. but should i wire them in series or parallel? and just to clarify series is the - on one light to the + on the next one with the resistor in between? or parallel where i run a positive run and a negative run then attach all the + to one side and all the - to the other???
and what kind/ size of power wire should i use? i know how to solder, but just not sure how exactly i should wire them up?
thanks
Mr.meyhem
Mr.meyhem
Cold as F***, MN
snoopdan
