So I Called Jl...
goodstuff
LOL
About going active. They told me not to cut the tweeter any lower then 4.8k which means I can't use the coustic xm3 or the memphis xo6..So first off, I'm looking for some other resonably priced brands of active crossovers. They also told me the mids will handle 75 rms and the tweets will handle 25 rms. So am I correct in thinking that it's the crossover that's sort of a weak point in terms of power handling? because they rate them together with the passive crossover at 60 rms. I've got the 6channel e series jl amp...the manual says 150x3 bridged ,can I go with 150x2 to the midbasses and 45 rms to each tweeter? Another thing I hadn't really thought about was matching the level of the tweeter to the woofer since they will be independent of each other...I know how to match left/right by measuring/matching the voltage at the output of the amp but not sure about matching with different drivers....one more question should I use different test tones to set the gain of the mid compared to the tweet...ie use 10k for the mid and something higher for the tweet?
Listen to it.
No test equipment needed other than your ears //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Or good mids that will play that high smoothly //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well yeah, that would work too.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I still prefer a lower crossover point myself though.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I personally perfer higher //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
My mids and tweets are at 4khz and my midbass are at 250hz
Tweets playing 7.1k+
Midranges playing 280-6.3k
Midbasses playing 63-250
Different strokes for different folks.
As for test tones, play a track that's about in the middle of the playing range. If your tweeter is playing 4.8khz+ then just play a 10k or 12k track
Tweets playing 7.1k+Midranges playing 280-6.3k
6.3khz-7.1khz there is a slight gap in there wouldnt you say? Unless youre using 6db slopes I see no point in that. Also up that high IMO its harder to get a midrange speaker to play smoothly vs a tweeter. Your response graph would look all crazy up that high with a mid...EQ nightmare IMO lol.
Mine is as follows.
Tweets 4khz+
Midrange 250hz-4khz
Midbass 50hz-250hz
All have a 24db slope
Yep, there is a gap, but if you take a look at the FR response you'll see that there is plenty of sound in that range (the dip is around 5k, but 6k-8k has plenty of playback):
I do this to help cut on sibilance. The slopes are 24db for the tweeter & 12db for the midrange.
Not really. Setting x-over points at the same spot creates a lot of overlap. I've tried a lot of spots and what I have now seems to work the best for me.
http://img407.imageshack.us/img407/9333/leftsidefacingmicforwardp0.jpg
That would make me retune...personally I have 2 or 3 settings on my gear.
1)flat for RTA runs
2)gentle downward slope
3)tuned to how I like
Ill see if I can dig up a few of my old RTA pics when I get home.
Very true...its all about what works best for you and what sounds best to you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
goodstuff
LOL
goodstuff
Northeast
goodstuff
