smoke
I think......................you should take the sub....since it is probably just about to take a shit now, put it on the edge of the roof top hooked to a string and stand under the sub and pull string.
Best solution by far!
Poor Pioneer sub. Also not the equipment, just retards who don't know how to set shit!
no i knew it wont suppose to he just got a 1500 instead of a 1000 and it started smoke no shame i got mad as hell thou almost beat his azz because of it.. i aint going to send ppl to him...now but it still knocks no harm done just heat the voice coils up a little
Actually, that 1500 is a good match for that pioneer sub. We called up autotek and that amp only puts out like 750 watts rms, not 1500 watts rms like it says on the box. But I'm talking about street machine, not the mean machine.
here is what the specs are from what autotek told me
Details:
**Features: **1-Channel Operation **Mono-Block Amp Design **375 Watts x 1-Channel @ 4-Ohms **750 Watts x 1-Channel @ 2-Ohms **1500 Watts x 1-Channel @ 1-Ohms **A/B Class Amplifier Topography **Stable @ 1-Ohm Speaker System Load **Pro-Fi MOSFET Outputs **ASPS (Auto-Step Power Supply) **Road Worthy TCID (Twin-Coil Isolation Design) **Fully Adjustable Pro-Design Crossover 24dB Subsonic Filter **24dB Low-Pass Crossover **Bass Thrust **Variable Bass Equalization **Remote Bass Control Included **RCA Line Outputs **Permits Amplifier Daisy-Chaining **4-Guage Power Connectors **SPECIFICATIONS **Amplifier Class : A/B Class Amplifier Topography **Number of Channels : 1-Channel **Maximum Power : 1500 Watts **RMS Power Output @ 4 Ohms : 375 Watts @ 1-Channel **RMS Power Output @ 2 Ohms : 750 Watts @ 1-Channel **Bridged Power : N/A **THD : 0.10% **Signal-to-Noise Ratio (dB) : 95dB **Frequency Response (Hz) : 15Hz~300Hz **Built-in Crossover : Yes **High-Pass Crossover Frequency : N/A **Low-Pass Crossover Frequency : 40Hz~150Hz **Bass Boost : 0dB~12dB **Bass Remote : Yes **Fan Cooled : N/A **Fuse Rating : 50A x 2 **Dimensions (Width x Height x Length) Inches 9.4" x 2.3" x 20.08"
loudazz09
loudazz09
loudazz09
always bump'n , nc
loudazz09
vegang
vegang
