Sold Small Amp Package Deal - MTX 251D, Alphasonik MA-2025, Alpine 3522
Suicide Bobb
SPLC Fails
∞MTX 251D
∞Alphasonik MA-2025
∞Alpine 3522
∞MTX 251D: 7/10 Cosmetic, 10/10 Mechanical. Missing two output terminal screws and the little light piece that sits right above the actual power light itself to alter how the light is distributed. I may have some screws lying around, and I know the general vicinity where the light thingy is, it's just a small piece lying in thick carpet so it's not easy to find. Couple scratches here and there. Loaned it to a friend as well as a pair of my JL W4's because he needed some bass, and they definitely hit hard with that little amp, and sounded nice too. Very solid little amp, never shut off on him.
Specs (obviously underrated)
12.5v
2 Ohm Load 160 w x 1
4 Ohm Load 80 w x 1
14.4v
2 Ohm Load 250 w x 1
4 Ohm Load 125 w x 1
Dimensions
8" x 9.75" x 2.1"
20.4cm x 24.8cm x 5.3cm
Input
Hi Level w/ Smart Engage
Low Level Input
Crossovers
Low Pass @ 85Hz - Fixed
Thunder EQ
RCA Output
Full Range
∞Alphasonik MA-2025: 6/10 Cosmetic, 10/10 Mechanical. Zed-Made. The wiring harness had very short leads when I got it, so I extended them. I need to redo a couple, but I will leave that up to the buyer to decide if they want me or them to do so. Would make a killer tweeter amp in an o/s install. I ran it in my Saab for a while hooked up to some Type R components, and it sounded very smooth. Been sittin around ever since.
Specs (underrated as well)
14.4v
25x2 @ 4ohms stereo
50x1 @ 4 or 8ohms mono
Frequency Response: 20-20khz
THD @ rated power:
∞Alpine 3522: 6/10 Cosmetic, 9/10 Mechanical. I say 9/10 given that it appears that one of the internal ground has been redone (left bottom side of the guts picture). It works fine though. Ran it around the same time I ran the Alphy, both performed similarly. Another good choice for some tweets. Geoff was the previous owner of this amp, and I believe he told me that he was the one who painted the bottom plate black. I am not sure if he was the one who redid the ground or not, but I don't believe he did. Also, I do not have the plugs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I cut up some butt splices that fit snugly over the pins when I ran it.
Specs
No. of Channels 2 Channels Bridgeable
Power Output 30Watts RMS per channel, 70Watts RMS Bridged 4 ohms
Load 4 and 2 ohms
THD 0.08% max.
Signal to Noise Ratio -100db
Bandwidth 20Hz-100Khz
Special Features:
Short Circuit protection 150 watts trigger sensor
DC Offset Protection Sensitivity 1.5Volts DC sensors
Speaker Inputs Sensitivity 1V to 2 volts
RCA input Sensitivity 0.1 to 1v 0.5 nominal
Remote ON/OFF Antenna Input level
Topology Class A/B
$100+Shipping for all. Price is FIRM. Will entertain trades for other audio equipment.
Buyer pays shipping on any trades for his and my items. I don't have any money to spend on anything right now considering how much debt I'm in. I have other items to throw in though if you want to trade items of greater value.
If you are a well respected buyer/seller on this forum, I will ship first. This is up to my discretion. I gave BassAddictJ this privilege, but we never ended up trading. So if you are like him, you may be in luck. I also will be more than happy to take pictures of anything and everything related to these items that you request given that you are actually interested in buying them. Ask any questions you have. If you want, I can take a video of them all running, but I have a tight schedule so we'll have to play that by ear. I want to assure the buyer/trader that everything he receives is in the exact condition that he expected them to be in. I am a good packager as well, so shipping should not harm the amps.
Geoff - I will subtract $80 from the amount I pay you back if you want these, unless someone steps in and offers $100 (first priority to you if someone does step in after you accepted the $80 offer, and you still want them for $100). I'm hoping that makes sense to you and the potential buyer?
I have been spending the past hour trying to upload these pictures from my Blackberry and it's still not working! Shouldn't be this difficult...I'll try again tomorrow after class, which should be around 5pm Pacific Time. Hopefully the thread won't be deleted by then! Here's a couple old pics in the meantime...
Alphy on the left
Actually, that's all I have right now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Oh well.
I have had a lot of this guys stuff come through my house from time to time and never had any issues. Good buyer, just make sure you get a DOBW33D CD from him lulz
Thanks cutie //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Free DoBw33d mixz for whoever buys this!
Still working on your CD...my personal computer is down right now, I'm using a different one and don't want to hassle with transferring all the music over.
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
Suicide Bobb
