small 5/4/2/1 channel amplifier list
raverx3m
so i ve looked thru the search results for a small 4 channel amp and wasnt impressed.
most of the conversation is like what??? did yo u mean oh that noo!!! budget???? oh i got one of those. hos big you want it but its not the one i meant.
so can we please sum it up into one topic?
to make things easy id ask everyone that visits to list the smallest amp they personally seen for 5/4/2/1 channel
what i mean is
you have seen some amps since yo re on this board so you must have an idea of what is small.
list the model of the amp and channels and wattage if you know.
what i will do is go thru the forums again and collect all the usefull info and put it into one if thas cool with everyone..
heres what i gathered so far:
mono
Xtant 1.1i class D
Watts per Channel 4 Ohm 1 x 100
Watts per channel 2 Ohm 1 x 100
Input Sensitivity 100 mV - 8.5V Unbalanced, 200 mV-17V balanced
Dimensions 6.5 L x 5.81" W x 1.63" H
sony XM-1s class D
290 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
low-pass crossover (50-300Hz, -12dB/octave)
variable bass boost (0-10 dB at 40 Hz)
switchable subsonic filter (15Hz, -12dB/octave)
8-13/16"W x 1-3/4"H x 8-13/16"D
KS 500.1 Mini
Power @ 4 ohms 310 X 1 watts @ 14.4 Volts
Power @ 2 ohms 500 x 1 watts @ 14.4 Volts
Size 11.6' (L) x 5.15” (W) x 1.7”(H)
JL audioHD750/1
Infinity KAPPA ONE
pioneerGM-D7400M
pioneerGM-D8400M
2ch
4ch
sony XM-4S
50 watts RMS x 4 at 4 ohms (60 watts RMS x 4 at 2 ohms)
50 x 2 watts RMS + 120 x 1 watts RMS power bridged output at 4-ohms (4-ohm stable in bridged mode)
4- or 3-channel output (no 2-channel output)
switchable high-pass filter on front two channels (80 Hz, -12 dB/octave)
switchable low-pass filter on rear two channels (80 Hz, -18dB/octave)
variable bass boost on rear two channels (0-10 dB at 40 Hz)
8-1/8"W x 1-3/4"H x 8-13/16"D
arc audio KS 125.4mini
Power @ 4 ohms 75 X 4 watts
Power @ 2 ohms 125 x 4 watts
Power @ 4 ohms (Bridged) 250 x 2 watts
JL Audio HD600/4
Alpine PDX-4.150
Alpine PDX-4.100
Infinity KAPPA FOUR
5ch
Alpine PDX-5
Infinity KAPPA FIVE
JL audioHD900/5
no need for attitude bro you re not in highschool anymore( i hope)
i was just trying to collect all the small amp data to one topic so its easier to search.
OK, I'll play:
JL Audio HD900/5
Number of Channels: 5
Rated Power Front Channels: 100W RMS x 2 @ 4Ω (11V - 14.5V) 75W RMS x 2 @ 1.5-3Ω (11V - 14.5V)
Rated Power Rear Channels: 100W RMS x 2 @ 4Ω (11V - 14.5V) 75W RMS x 2 @ 1.5-3Ω (11V - 14.5V)
Rated Power Subwoofer Channel: 500W RMS x 1 @ 1.5-4Ω (11V - 14.5V)
Dimensions: 10.74 in. x 8.29 in. x 1.93 in.
Cost: If you have to ask, this probably isn't the amplifier for you!
im not going to give you specs on them because i dont feel like looking them up. but small FOOTPRINT amps that come to mind are
the arc mini's
elf audio (same as the arcs)
lanzar opti's (4x400d's etc..)
alpine pdx
...drawing a blank.
no need for attitude bro you re not in highschool anymore( i hope)i was just trying to collect all the small amp data to one topic so its easier to search.
'Twas a joke son.
A return on the one you left in my thread.
Namely, this photo.
raverx3m
raverx3m
new york
eharri3
