skar audio amplifier?
****UPDATE**** i was just browsing around the SSA store and yea SKAR is coming out with a 1500 watt monoblock if i read correctly they're doing a pre-sale and being released in february
i hate companies that charge an arm and a leg for a 1500w under rated amp that may do 2200@,5.... but when it comes to a 2400wrms @ 1 ohm for $329 (brz2400) its too expensive..... people are tards
lol that's how it usually is.
And guys SKAR is a dealer drivin company. That is why the prices won't instantly be cheaper then most. These are Korean boards as well so it wasn't made the cheap way that's for sure
there are so many korean boards out that right now it doesnt rally have the means to jack up the price 400$
Heysoos! that expensive? I've never had the money to blow to see if products like that are worth their cost; but I've always had a sneaking suspicion that they are not; but then again sometimes when it comes to having the most realistic reproduction it is always worth it for the best (not to say SA and Skar have the best)
There is a reason the BRZ is so cheap. Its called rated at 10%THD. If you just want cheap noise go for it. But dont even listen to a nice amp. Really as power hungry as the budget amps are whats the point. It will cost you just as much in electrical to keep the voltage up on it then to just get a better amp to begin with
baahaha. someone has been misinformed.... those amps are not near 10%. you forgot a decimal . and they are far from power hungry. but im sure someone that hasn't had experience with them (like you) would know everything about them.
Renzone3
ATLien
Renzone3
Fairburn,Ga
DJ_FURY_GME
