SimpleTech External HD?
yne721
SWINE FLU!!!!
i bought a simpletech 250gb external hd because it was on sale at bestbuy while i was there, and figured i might as well buy one now because i'd been thinking of getting an ehd for a while.
supposed to be plug and play but for some reason i can't find it under "my computer" when i hook it up.
can anyone help me? i don't really want to have to call their support number tomorrow...
Not being an *** here, but did you plug it in? It should have came with a power cord.
If it is powered up and plugged in, you need to check if the PC realizes its plugged in at all. To do this, do:
Start -> [Right Click] My Computer -> Properties -> Hardware -> Device Manager
In this, look under "Disk Drives". If it isn't there, look for any yellow question marks in the list, it may just not be installing for some reason.
if your using your front usb ports dont try using the back ones. For some reason the front usb ports dont have as much power as the back
That's because front USB ports are connected via a cable on the motherboard, the rear USB ports are directly attached. However, I have never seen an external HDD that didn't have a power adapter, so it shouldn't actually draw power from USB anyway.
it is under disk drives. it just doesn't show up in the my computer folder...
Had that happens with a lotta USB devices on our Dells at work.. no clue why..
Same USb dongle or drive will work fine on my laptop, then i gotta search for it on the Dell..
usually the second it connect, a window should come upo asking what u wanna do..
click 'view folder".. if it doesnt do that.. youre f'd
then i guess i'm fucked //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Did you ever get it working?
no
right click my computer, manage, disk management, find the drive and format it
it doesn't show up under disc management
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
Scoobydoo
Mike Mccabe
