Simple Voice Coil Clarification
Do_
Ok I keep trying to figure this out but I am not getting it the more I read the more it gets confusing.
On a DVC Sub, lets say a Dual 4. If you wire it Parallel does it drop back to 4 or to 2? What confuses me is that the sub is technically an 8 ohm load by itself? Then paralleling it should drop it to 4? Or is it per coil, each 4 goes to 2 and it is seen as a 2 ohm load? I'm basically trying to get a 2 ohm load out of my amp and I just need to know if I should look at DVC 2 or DVC 4 Subs. I am looking for it mono so I can't do a stereo 2 ohm load.
The load would be a 2ohm load
No, the sub is technically a dual voice coil, 4ohm/coil load by itself.
How you wire those two coils determines what the final impedance will be
No, paralleling two 4ohm voice coils = 2ohm final load
It's per coil.
And each 4 does not go to 2 (whatever that means). You have two 4ohm loads....wiring them in parallel results in a 2ohm final load.
The individual coil's impedances don't change. You still have two 4ohm coils. But wire them in parallel and you now have a single 2ohm load. Wire them in series and you have a final 8ohm load.
That depends on how many subs you are wanting to use. If you are wanting to use two subs, then you will need two DVC 2ohm/coil subwoofers. Wire the coils in series-parallel and you have a final 2ohm load:
If you are using a single subwoofer, then you will want a DVC 4ohm/coil sub and wire the coils in parallel:
Do_
Do_
Here
Raisedin305
