Simple RCA questiom for the pros
dkc62
SoundStream®
Does a company make 4 channel RCA's with one end having one two interconnectors and the other side having 4 interconnectors for the 4 channel amp?
See my stereo has one bass amp out put and one for another amp. I've been looking at all the 4 channel rca's and both ends have 4 connectors. Please explain because I'm ready to buy asap.
So you want 2 on one side and 4 on the other??
do they make one I want or can I use the ones eith all f interconnectors and not usr two of them
Sorry for all the bad english I was typing and talk on the ohone at the same time.
I do have a splitter but all I was wondering is can I bypass the. If a company hasn't ever made a type of rca like that then gamnit thats a new RCA market
"Have one pre out put on the back of your cd player and need to hook up two amps or a single four channel amp? Well fear no more. Buy my new set of RCA's that has two interconnectors for your cd player and at the end of the other side of RCA's you'll have four interconnectors!"
You are definately going to have to clarify your sentences.
Anyway, if you are running 2 amps you can just run a cable from the output of your first amp to your second. If you have a 4 channel, most of them have a switch that connets the 1st set or rca to run all the channels. And I dont know of anyone that sells a cabe like that off the top of my head. As for quality cables; Stinger Expert Series, Monster Cable Series 400
One of my other pre outs is straight for bass the other pre out is gor another amp that requires to in puys. So I'm not going to get a 3 ft rca cable from my bass amp and stick it in my mids and highs amp.
If you plan on getting a Stinger Expert or Monster Cable 400, expect to pay anywhere from $20-$40 for 1. There is no point in getting a really good splitter if you aren't using the same quality cable coming from the head unit though.
dkc62
SoundStream®
dkc62
WPB FL and Eastern Shore VA
dkc62
