What behooved you to purchase the drivers you did?
Why an 8 paired to a 25mm dome tweeter?
I have a hard time believing you'll have a homogeneous transition between the tweeter and the midrange, you'd be exploiting each's weakness. The Peerless is going to struggle greatly below 3khz im guessing, and with the Seas 27TBFCG (phenomenal performer that performs equally as incredible as its MUCH more expensive brother) being a few dollars more why did you choose it?
The silver flute specifically arent known to be very renowned performers...why not a smaller driver or a better engineered driver? I havent read any reviews on the specific driver you're using, but I have read some reviews on its smaller brother, the W14 (~5.5). It was specifically recommended to be used
Why not the Dayton RS225 (if you REQUIRE a low-cost 8, although most drivers of this diameter are incredibly undesirable for the upper midrange and lower treble) and RS28A/Seas 27TBFCG?
I found some data sheets on that Silver Flute and it appears to have a NASTY breakup occuring between 4-5khz and manifests itself sharply from 2khz upward. If you DO intend on using this driver, I would highly recommend on using an extremely high order filter around 1000hz maybe 1100hz. Otherwise you're going to have a very offensive passband (lots of odd order harmonics) in the area where the human ear is most sensitive...big no no.
I think he should be fine. This is a very good learning project. I give him the thumbs up!Learn by expiramentation :thumpsup:
Word up, thanks manI think he should be fine. This is a very good learning project. I give him the thumbs up!
Well, currently I have the design plans all together, and the parts on hand.You are misguided if you believe your 8 is going to cross that high without *****ing...a LOT of it mind you lol:laugh:
You can get an idea about how a driver is going to perform distortion wise by observing its frequency response. At 3-5khz we have a large peak, we will have high levels of 2nd order harmonic distortion between 1500 and 2500hz. We will also have high levels of (offensive) 3rd order harmonic distortion between 1000 and 1667hz as the 2nd and 3rd harmonics are multiples of the original peak. See my point? Crossing that high is a really bad idea.
Thylantyr,W20RC38 - Wool-filled Paper Cone Wooferhttp://www.madisound.com/silverflute.html
If the woofer you have is untreated paper cone, then read below.
Here's a tip. Some of the best sounding midranges are paper treated cones.
Non treated paper they can have sonic issues at the higher frequencies.
You can use the lacquer cone treatment mod on that woofer to tame the higher
frequency nasties, it should sound pretty sweet.
Get a $5 spray can of lacquer, clear type. Example;
http://www.builderdepot.com/RUSTOLEUM_BM/prodimg/6021257.jpg
Get an empty soda can like so;
http://moon.ouhsc.edu/dthompso/namics/gifiles/coke_can.gif
Get a 1" cheap paint brush like so;
http://www.impactdecor.com/acatalog/brush_syn_25mm.jpg
Cut the empty soda can in half.
Rinse and dry the can.
Spray some lacquer in the soda can.
Dip the paint brush in lacquer and apply a thin coat to the woofer cone, dust
cap, but not the surround.
Let dry. Repeat about 4 to 6 times to build up.
The spray can lacquer is ideal because it's not thick like the non-spray type,
this allows it to soak in the paper fiber. Lacquer coats meld with previous coats
to form a thick coat.
This will add mass the woofer, lower Fs, tame high frequency nasties, and you
loose a little bit of sensitivity. The paper is now protected against the environment and will last forever vs.
drying out and getting brittle over time. The SQ should improve.
Try this out.
Do two coats. Listen to the woofer full range, free air. Compare the sound to the unmodded woofer.
If you think there is progress, then do two - four more coats until you think it's good. The full range sound
test will tell alot, trust your ears.
