Significance of "Dual Voice Coil"??? Please Define for me.
Epitaph to War
I've never owned a sub that has dual voice coils. What exactly does that mean and what are the advantages/disadvantages??? I've been considering purchasing a Diamond Audio 12" M6 that handles 800RMS and has dual voice coils... now PLEASE tell me... does that mean that I can send 800 watts through 2 channels to the same sub (2 routes, 1 for each coil), or does that mean that I can send 400x2 to the sub for a TOTAL of 800RMS?!?!?!
Please help me out with this... I'm looking to purchase the sub and a decent SQ amp for it very soon.
Many ThanX and Cheers
PS... while on the topic... what amp would you all suggest for this particular sub?
Well, all a DVC sub does is give you more wiring options. So, a DVC 4-ohm sub can be wired at 2 ohms, or at 8 ohms. This allows you to use more than one sub off an amp, or allows you to use class D amps and have a lower ohm load. One downfall is that sometimes you can't work out a proper ohm load for your amp.
umm, i was kiding who is evreyone i said to him cus he used caps alot like he was yelling. there is no need for you to make a issue out of absolutley nothing
Dang, that was fast guys. ThanX alot. What about an amp though... what would you recommend for a 12" Diamond M6? I've heard they require LOTS of CLEAN power to perform to their fullest. If it is power hungry, should I send it the full 800RMS or close to it? Or would something like 500RMS do the trick just fine?
THX Again!
Originally posted by Epitaph to War Dang, that was fast guys. ThanX alot. What about an amp though... what would you recommend for a 12" Diamond M6? I've heard they require LOTS of CLEAN power to perform to their fullest. If it is power hungry, should I send it the full 800RMS or close to it? Or would something like 500RMS do the trick just fine?
THX Again!
500-600 would be just fine, what kinda enclosure you gonna put it in?
If you don't mind me asking... why put the port in it? I thought with SQ subs, small and sealed was the best route to take? I had a 12" Eclipse Alum in a 1ft sealed box and I loved it... just asking... I really have no idea about this stuff... still learning here.
Epitaph to War
Epitaph to War
Georgia
dave_3148
