Qexler
Hey guys, I am running a single AQ HDC3 10"
off of a Audiopipe 1500.1 D at 1 ohm load.
I seriously doubt it is seeing a TRUE 1500W RMS but I do have a slight light dim only when the sub switched up notes. Right inbetween the switches it will flicker. If it was hitting a straight tone it has no problems at all...
Currently I am using a 130Amp alternator And the stock 750 cranking amp battery. I was wondering if the SHURiKEN SK-BT20 would help this issue, if not fix it completely? I also later plan on adding 0 gauge big 3 in the future.
Thanks guys!
Thanks guys!
