Shiva acting up
supa_c
Abministrator
Im about to beat this sub to a pulp:pissed: . The stupid thing is acting all retarded.
I turn up the volume....nasty bass. No where near X max...whats the problem ???
The gain is on 1/2 and no bass boost on the amp.
It is under warranty (i hope) so i might send the rotter back.
Are you sure it's not the amp? Have you tried a different sub on that amp? Tried the Shiva on a different amp? Any chance the speaker wire or something is touching metal and causing funky stuff to happen? Stray strands touching other terminals or anything of the sort?
Ive used both MA Audio amps, same result
The gain isnt even at 1/2 its 1/4.
I doubt its some wire touching something it shouldnt be.
I'll have to check it on the 26th.
The other amps i have are not installed at the moment.
No way amp i putting the 4000D on it
There was only 1 B stock Shiva //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It just sounds bad all the time ( at higher volumes), its a hatch so you hear everything.
supa_c
Abministrator
supa_c
In a chair
supa_c
