I just was wondering why most sites seem to recommend wiring two 4 ohm DVC subs in series then connecting them in parallel to achieve a final 4 ohm nominal impedance?
For example, check here: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Why wouldn't the third option of paralleling the coils on each sub then externally wiring in series work to achieve a 4 ohm load off of two 4 ohm DVC subwoofers? Correct me if I am wrong, but paralleling each sub should give me 2 ohms nominal per sub, then wiring them externally in series should bring it back up to 4 ohms nominal, correct?
I ask because I was initially going to use a 1 ohm stable amp to run my subs, but now I am thinking about using my cheaper 4 ohm stable amp to run them. The subs in question are two JL Audio 10w3v2 D4 subs.
ETA: I am getting lazy and I don't want to pull the subwoofers out of the box.... Again!
