ifandorbuts
contest # 2
This time I am giving away all of my new products.
I have 4 new products coming out this month.
Motor Mat - a thermo/acoustic hood liner
STFU-80 - 80 mil constraint layer vibration damper
OC-38 - open celled foam with PSA, weather stripping in 4 foot sheets
Vinyl Liner - Multi layer composite, foam vinyl barrier absorber with PSA
This is CONTEST #2 for September
there will be a total of 4 contest this month
1 for each product
This first contest is for OC-38
OC-38 is a simple yet highly effective product consisting of acoustical grade
open cell foam and an acrylic pressure sensitive adhesive. OC-38 is designed to
adhere to the back of plastic panels to absorb rattles, and diminish airborne
sound. Once installed, it creates a cushion between the plastic panel and the
metal structure the panel is secured to. OC-38 helps reduce road noise, engine
noise and exhaust noise within the cabin of your car and helps keep the music in
your car. It is kinda of like weather stripping in sheet form, only made out of acoustical foam. Very simple, yet highly effective.
This kit has 18 sq feet in it
.375 “ (9.51 mm)
1.9 lbs/ft3
-67 °F to +280 °F.
Recommended Installation locations
Behind plastic panels, ceiling, walls, rear dash & doors
ASTM C384-77
06 @ 125 hz
10 @ 250 hz
14 @ 500 hz
47 @ 1000 hz
59 @ 2000 hz
85 @ 4000 hz
If you want to be considered for CONTEST #2
Send an email to
contest@secondskinaudio.com
Put the words OC-38 CONTEST #2 as the subject line.
As usual I will have my wife randomly select 1 winner.
winner will be selected on the 9-20-03
If you are the winner all you do is pay the $10 shipping charge
Good luck.
ANT
1 for each product
.375 “ (9.51 mm)
1.9 lbs/ft3
-67 °F to +280 °F.
ASTM C384-77
06 @ 125 hz
10 @ 250 hz
14 @ 500 hz
47 @ 1000 hz
59 @ 2000 hz
85 @ 4000 hz
Send an email to
Good luck.
ANT
