Selenium D250 - use with HC23-25 body for incar?? Loud easy horn??
Im looking to use a Selenium D250 as a horn driver to pair up to some 10" pro audio mids and selenium st350 supertweets.
Selenium D250-X 1" Phenolic Horn Driver 1-3/8"-18 TPI | Parts-Express.com
Which body have you guys heard of success with for incar use, under the dash, I need to see if I can pyhsically fit these things. Im looking for loud and clear with easy eq, I have an active pioneer premier 860 to eq them with
Selenium HC23-25 1" Exponential Horn 100x40 1-3/8"-18 TPI
Theres a lot of bodies for the thing though and a search didnt turn up much
Those Seleniums are loud as crap, but not the best sounding. Ive ran a ton of then, but usually run them under my truck on the outside with their own amp on a toggle switch, so I can turn them off when Im not at shows.
What 10s are you running? Also, are you stuck on the Selenium ST350s? Right now Im running 8 Eminence Delta 10s and 6 Selenium ST350s. Im swapping out to the DB Drive P5-5Ds. They sound a million times better, can cross way lower, take more power, and are louder. Every now and again I hear a ST350 thats scratchy and Im only running 60w each, with them crossed at 3100hz. Ive had the DB Drives crossed at low as 1600hz with 125w each, and they take every bit of it. Almost extends down as low as the horn will.
If you were dead set on horns, Id spend a little more and get something nice like a higher end Selenium horn, or even a B&C horn.
CoilBurner
Banned
CoilBurner
Waco
galacticmonkey
