Security Screws
CadillacMatt
Disturbing the Peace
They look awesome.
But what you have to realize is the only thing you should worry about securing is your subs to your box. You don't have to buy those special security screws if you don't want. Just get some regular hex screws. Most theives will only have a screwdriver.
They look awesome.But what you have to realize is the only thing you should worry about securing is your subs to your box. You don't have to buy those special security screws if you don't want. Just get some regular hex screws. Most theives will only have a screwdriver.
I think it might be overkill to bolt the box... I mean it weighs upwards of 60 pounds and the subs are 32 each, so... 128lbs! That has to be one strong person or two hefty guys. The next option would be to try and remove the speakers.
I don't want to seem paranoid just prepared //content.invisioncic.com/y282845/emoticons/ponder.gif.ec2527b23f1d287b60dcbba54f95edba.gif
x2
My box is through bolted through the metal frame in the back of my seats with these:
Mine are longer, thicker, and silver, but you get the point.
They're badass bolts. You just need to bolt it on the other side. If you want to be UBER safe, you can try to find these, then leave one side of your box off and use these to tighten your subs. Only bad thing is if you wanna take out your sub for any reason you have to break one of the box's walls //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
CadillacMatt
CadillacMatt
San Antonio, TX
IDSkoT
