securing plexi to mdf questions
traksta15
I love lamp.
So im thinking of making a box with a plexi glass window, my question is-how should I go about securing the plexi to the mdf?? The window won't be very big at all, about 12x12ish, maybe smaller. Would simple clear silicone sealant work? My plans are to make the back of my box have a window, then attach the plexi to the back therefore covering the window, then screw/glue the back mdf piece (with plexi) to the rest of the mdf box, I hope that explains it well enough, lol. Thanks in advance!
I have always been told to use lexan rather than plexi. Lexan isn't as flexi as plexi. Where 3/4" plexi is used- 1/2" lexan can be used in it's place.
No you cant just glue it..
You need to drill and screw down. But be careful, it can be cracked easily and if you drill to fast, it heats up...
I recommend using Lexan for the enclosure...it is stronger and drills with a regular drill bit
with out cracking and it is crystal clear.....
I agree
lexan can be picked up at an lowes or Home depot. It really is drill friendly.
As far as attaching it, the cleanest way would be with the aformentioned screws. I'd also reccomend a rubber or dense foam seal around the edges. This will keep the enclosure air tight and also act as a spring lock washer to keep the screws from backing out.
traksta15
I love lamp.
traksta15
Mcalester, Ok
helotaxi
