Second Skin Damplifier B-Stock
Decado
I was just wondering how this stuff compares to the A-stock. Is it not going to stick as easily and be harder to install, or come off in high heats? If I can get away with using this stuff I will because it's alot cheaper, or should I just be getting A-stock?
Not necessarilly sucks. Because you are still getting a great product for a cheaper price //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There could be various different issues...heat tolerance,adhesive,creasing,etc... Although Ant would be the best one to answer this.
x2. Although he already did.
How good are Second Skin B-stock products?
All second skin B-stock products will function exactly as our line of A-stock products do. Sometimes they have cosmetic flaws, or are return items that can not be sold as new. They work just as well as our A-stock products.
A stock and b stock are identicle with the exception that B stock has alittle extra foil around the edges.
same heat tolerance
same size sheets
same thicness
nothing is different accept 1/4 inch of extra foil on the edges
ANT
A stock and b stock are identicle with the exception that B stock has alittle extra foil around the edges.same heat tolerance
same size sheets
same thicness
ANT
Lol, then i see no reason not to buy b-stock then, thanks man.
Decado
Decado
Minneapolis, MN
twoohfour
