Seas 27TDFC Tweeters - $55 shipped Specs (PDF)
Toss-up b/t 27TBFC/G as the best Budget DIY tweeter on the market. They can be crossed as low as 1500 Hz. If you have never heard about these then you need to do some more research. I bought these used from a fellow forum member. I never got around to using them. They are in perfect cosmetic condition and I assume perfect functional condition also (I will test when I get home).
Kove KXS4.2 4" Coaxil Speakers - $20 shipped Info
These are some high powered (80 RMS) Bi-amp (separate tweeter/mid terminals) coaxial speakers. One has never been used and the other has been used for approximately 20 hours. The used one is exhibiting some voice coil scratching (noticiable when depressing the cone). The t/s parameters look good but I went a different route.
Power: 80 Watts RMS
FS: 100 Hz
QTS: 0.67
Vas: 1.68 L
Res: 100 - 20kHz
Pioneer Premier GM-X402 - $25 shipped
A-Class (purple) amplifier. Continuous Power: 35W x 2 @ 4 Ohms (20 - 20,000 THD= 0.08%) 80W x 1 @ 4. This amplifier would be great for tweeters and mids. Cosmetically 7/10
Planet Audio TT4200 - SOLD Info
Seas MP12VC/VT-NHT Midrange Drivers - SOLD Specs (PDF)
Optima Red Top 75/35 - SOLD Specs
Power: 80 Watts RMS
FS: 100 Hz
QTS: 0.67
Vas: 1.68 L
Res: 100 - 20kHz
