Flipx99
Violator of Terms
In my newest box build I have two seams. I have seams because I am building around the jack holder.
In retrospect, I should have cut out the correct dimensions and used a jig saw. But that is experience.
What should I do to seal the seam, and make in strong (not a point of flex). This will be at the bottom. Here is what I was thinking:
1) Use resin to seal the seam. I am not sure what proportion I need to mix the resin and hardener to ensure it gets abosorbed by the mdf instead of sitting on top.
2) Use a 2" wide piece of mdf to build a bridge over the seams. I think this will assist with the stregnth as well as provide bracing. I was thinking of adding these in various places.
Any other suggestions?
