SAZ200d vs AQ2200???
if i had to guess, you are taking a swipe at me. it was not necessarily the price, but the rated power per dollar was really good and the amp is built solidly. good build, good price, and +/-3kRMS@2ohms is perfect for me. im only running 8's.
I wouldn't call it a swipe.
Is it or is it not cheap ? Was that or was that not part of the reason you got it ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Looks like you just agreed that is a reason you purchased it - so I was correct that you, and other buyers, like the Audiopipe product because it is very inexpensive.
I've tested nearly every amp from the build house that makes those - they are all okay but I have never been overly impressed with them. I wouldn't say they **** either - but they are priced the way they are because they are very cheap to make.
the sundown is stronger... the sundown 1500 will also do 2500 @ 14 volts the 2000s power supply is about 900 watts stronger.
I highly doubt the 1500D can produce 2500 watts unless it is around 16v. But other than that I say get the SAZ-2000D, it'll be a power house
loyd has tested the to do 5700 strapped @ 14v..my 1750 are nearly identical and i got 3200 out mine @12.1
It's 5677watts at the start of 17.9v dropping to 15.5v on a 1 ohm load strapped which means each amp is wired to .5ohms. I own a SAZ-1500D so I'm not knocking on it by any means. It's a great amp. Check it out for yourself and read some more...a little closer.
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7116
I say AQ, but I'm biased because I will be running all AQ shortly. Ive had an AQ2200D for several months but havent hooked it up yet. I have hooked up the AQ4X90 and I was very impressed. Great power for a four channel. I have also emailed AUdioque several times and was answered very promply. My car will be done very soon, and the videos should be very nice.
yea it was 17, but if voltage was 14.4 and remained 14.4 you would see vety close to that...depending on hoe they tested the that could be rms of the voltages... the mosfets used in the amps are capible of producing 2400(4 300 watt rms mosfets PER RAIL).. it can do more but your going to get major heat problems... note they where strapped @1 but rise was 2ohm so tech it WAS 1ohm per amp...
dsgb610
dsgb610
Columbia SC
jnralp00
NorthFramingham
    Jun 30, 2026
