saz-1500d
pinoywitboom
hey guys since i dont got a dmm handy, i want to set my 1500d as accurately as possible so can u guys who are running 1500ds or amps with similar settings give me a heads up on exactly what you guys have your settings at? ive recently been running mine on 2 type argh's and they get stinky within about 3-5 at times. so any help on settings so my amp sends a cleaner feed to my subs so they dont stink as much?
if your running them at one ohm then here is the formula
Square Root(power x Resistance)
Square Root(1500 x 1)
Square Root(1500)
38.72 AC Volts makes 1500 Watts at 1 ohm
I doubt you're getting them stinky at 2 ohms or higher so I won't do it again for that resistance level, but the formula is there if u need to check my math.
[Edit]
Just read u didnt have a DMM handy, in which case I have no clue what to set your gain too, as I don't know the output voltage on your head unit, but you could try just turning the gain lower than you have it until you get a DMM handy...
pinoywitboom
pinoywitboom
Da Big Isle
Alpineforever
BP1Fanatic
BP1Fanatic
