SAZ-1500D V2 is a monoblock?
This is one of the most understood subjects by noobs ever. It has two sets of outputs for ease of wiring and nothing more. Think of the positives as one buss bar and the negatives as another. Both positive terminals are connected together internally and both negatives are connected together internally. The thing that really matters is that you get your subs wired correctly. This is what is going to dictate your nominal impedance/ohm load
Sundown Amplifier FAQ - SSA Car Audio Forum
8) Why are there two pairs of connections on the mono-block Class-D amps? How do I bridge them? - 4/21/08
You do not bridge them, it is a mono-block amplifier.
The connectors are in parallel inside the amp. If you hook 4 ohms to each one, you get two ohms. If you hook 2 ohms to each one, you get one ohm.
They are also there for strapping the amps, as pictured above.
:facepalm:
---------- Post added at 08:39 PM ---------- Previous post was at 08:39 PM ----------
Oh crap so then if I hook 2 ohms to each output I get 1 ohm?
Read.
Haha I understand how it works now, thanks guys! I was confused since the smaller amps are not wired together as a monoblock on the inside. But hey now I know! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Patthehat033
Patthehat033
Missouri
Phoenix Risen
