SUNDOWN SAZ-1500D
290 Shipped
Used and does have a scratch(see pic)
Includes:
Bass knob
Manual
Sundown Sticker
Amp itself
Original box
Specs:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
290 Shipped
Includes:
Bass knob
Manual
Sundown Sticker
Amp itself
Original box
Specs:
* 1 Ohm Stability
* MSRP $799 USD
Rated power output
3000W x 1CH
1500W x 1CH
400W x 1CH
T.H.D @ 4 ohm
Fuse rating 40A x 4
