Rated power output
50W x 4CH RMS 4 ohm stereo
80W x 4CH RMS 2 ohm stereo
160W x 2CH 4 ohm bridged
Features and Specifications
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
12dB Octave Electronic Crossover Slope
Variable Subsonic Filter
Independent 1/2 Channel High Pass Filter Variable with x 10
Range Selectable Switch
Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Bass Boost Variable Control (0-18dB)
Variable Bass-Boost Frequency Control (35Hz-120Hz)
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Channel Separation 75dB
Signal to Noise Ratio >90dB
Fuse Rating 25A x 2
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
