Running Two Head Units?
gatorgrizz27
I have a Kenwood Excelon 589, along with the music keg. The CD player in it doesn't read discs about half the time, but everything else works. I was looking into getting a Pioneer 880 or another deck with T/A and was wondering how to hook up both of them. I need to keep the Kenwood to run the music keg, and need info about wiring the outputs of it into the 880. I am using the front and sub pre-outs, is there any way to hook these up as inputs on the 880 to use the time alignment while using the music keg? Could I use the RCA splitters backwards to turn the speaker / sub outputs into one plug to use in the AUX in on the 880 or would this not work properly? Thanks.
I have a Kenwood Excelon 589, along with the music keg. The CD player in it doesn't read discs about half the time, but everything else works. I was looking into getting a Pioneer 880 or another deck with T/A and was wondering how to hook up both of them. I need to keep the Kenwood to run the music keg, and need info about wiring the outputs of it into the 880. I am using the front and sub pre-outs, is there any way to hook these up as inputs on the 880 to use the time alignment while using the music keg? Thanks.
The 880 has an aux-in through IP-Bus, just run the Kenwood through the Aux-in on the 880. It will be like another "source" on the 880.
Though, the thing is... the Kenwood will still have it's own levels as well.
nG
gatorgrizz27
gatorgrizz27
Alva, FL
Daishi
