running my octane pg 5.0.1
On this forum you're not going to get much advice on running 2 different subs. Just not a great idea. Before we can tell you how to wire your amp we need to know the ohm's and dvc/svc of each sub.
All are 4 ohm and why isn't it a good idea it sounds good because ive already wired it but should I consider going eith 4 12 inch instead. I dont know what svc or dvc is
Single voice coil, and dual voice coil. If your subs are single voice coil there will be one set of terminations on your sub. 1 positive and 1 negative. There are two sets if the sub has dual coils. It is not advisable to run two subs of different sizes or different brands. Your simply doing more harm than good
provok233
provok233
Branson, MO
provok233
