running 2 6 volt batteries?
PioneerSPL1990
IM FER REAL!
i know it sounds dumb, but i found a 6 volt battery with a 210AH rating that is well within size limits for most classes, my question is, how will 2 of these series (to 12volts) work out, and will you loose any of that capacity (Ah) wiring them this way, and lastly is it even safe, it just seems that wiring two of these will probably give you the availability to hold a ~15V charge and give u nearly 410ah of capacity for only about $500.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
here's the link: PS-62000 Powersonic 6 Volt 210AH Battery
Yes i do, and i was subscribing to your thread the lazy way because i thought it was an interesting idea. Though now that ive had to type this the effort was in vain.
When series wiring the ah rating does not increase with the voltage, so you'll still have 210ah, but at 12V. Whereas parallel wiring increases ah but not voltage.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
668
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
PioneerSPL1990
IM FER REAL!
PioneerSPL1990
Canton, New York
profundus-sanus
