runing 16v
AmericanBass
Could i run 16volts on a american bass vfl 450.1? Im buying xs power 16v 1000d. Never ranvoltage that high, i was just curouis because i didnt want to fry my amp. Saftey first //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you are running 16v you also want a seperate alt or something to run your stock electrical. Your stock electrical will fry on 18.5v
this either dual alts or step down modules, and a 16v alt i have even used the kinetic 16v dual post as starter bats with good luck in the past as they act like an automatic step down.
I used the HC16s and they are IMO not a good solution
---------- Post added at 11:28 PM ---------- Previous post was at 11:28 PM ----------
Knowing all this i might just run 12v. Sounds alot simplier. Lol
yep
i agree but i havent had a problem with using one to hold me over till i get dual alts step down modules dont usually give me enough juice 30amps isnt enough for some electronic dependent cars
you can run more than one step down at a time, typically 3 is enough to deal with any cars electrical needs.
Unless you are into competing, running anything over 15.0v for a daily isn't terribly necessary. If you want to run a higher setup you can run a 14v system where your alt charges at 16v and your batteries rest around 14, but unfortunately there are very few 14v batteries on the market.
AmericanBass
AmericanBass
Louisville, KY
Kangaroux
