Hello,
I'm looking power for my new speakers, 4 RSD 6.5 coaxs...
My new speakers will arrive this week, and I have 1 OZ Audio VA50.4 50x4 @ 4ohm but I think is not enough
My budget is at max $250, so here's my options
Soundstream Rubicon RUB600-4 @ 12.5V
4 x 80W @ 4 ohms
4 x 150W @ 2 ohms
4 x 150W @ 1 ohm
2 x 160W @ 8 ohms bridged
2 x 300W @ 4 ohms bridged
2 x 300W @ 2 ohms bridged
Fuse: 2 x 30A
Eclipse XA4000 @ 14.4V "Class D"
* RMS Power (4 ohms) 125 watts x 4 chan.
* RMS Power (2 ohms) 175 watts x 4 chan.
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 350 watts x 2 chan.
* Peak Power Output 840 watts
* Min. Impedance Unbridged 2 ohms
* Min. Impedance Bridged 4 ohms
* THD @ Rated RMS Power
* Amp Preamp Outputs 1 Pair
* Built-in Crossover Yes - LP/HP
* High-Pass Crossover 30 - 500 Hz
* Low-Pass Crossover 50 - 500 Hz
* Subsonic Filter 18 dB @ 18 Hz
* Signal-to-Noise Ratio > 90 dB
* Fuse Rating 30A x 3
* Output terminals allow multiple in-line unit installations.
* Clipping indicator LED
* Very high efficiency rate with low current draw.
* Dimensions: 10-3/16"D x 15-3/4"W x 2-5/16"H
I don't want a lot of load on my alternator because I have a small car, for the Sub stage I will install Orion 600D 600RMSx1 @ 1ohm + Image Dynamics ID12V3 vented 2 cu.ft @ 30hz
What do you think ??? about the speakers amp? Thanks, and don't look my english
4 x 80W @ 4 ohms
4 x 150W @ 2 ohms
4 x 150W @ 1 ohm
Fuse: 2 x 30A
