rounding corners
Flipx99
Violator of Terms
I learned today that you should round the corners of the port and of the corner that port is on. How does one go about rounding. I have seen some moulding time materials made from wood used for homes which would look okay. Does one round all the corners or just the one where the port is.
What about sealed encloures?
I took 1/2 day to build my first box and I am unhappy with my comp results so I am trying to learn a lot more about it and take my time this time.
yes, the inside of the box as well. I learned that sanding it lessens obstruction to flow. I take this the next step. Everything inside smooth as glass using expoxy, fiberglass, perhaps other materials to ensure air flows out as smooth as possible.
poster board, staple gun, f/g, and resin..
tilting the box, pouring in resin, and let it cure..
simply run a piece of scrap through a table saw set to 45 degrees, flip it over and repeat.
What kind of resin did you use? COuld you use wax to achieve a similar effect or could it melt in a sealed enclosure?
ive said this before..if youre trying to get more output from a sealed encloser...either go ported or add more power..i honestly dont know if it will or will not make a difference, but i really wouldnt waste my time figuring it out. If there is indeed a way to increase output w/o me having to spend money and hit or miss ill take that route
those slots are where the actual port slides in for all 3...one was mis-cut by myself, kinda throws ya off.
'05.... Nevermind though. I think I'm just going to mount my amp somewhere else and keep the box I already have made. It's ported. 2.2 cubes and tuned to 34 hz.
It's just hard because my trunk is extremely small. It's about 9" deep. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Flipx99
Violator of Terms
Flipx99
Building 100
Race
vegang
vegang
