Rockford T1 D2 new model $150 Local pick up only Tampa FL
naughtyca
Rockford T1 D2 new model sub box included Local pick up only Tampa Florida
bought 3 mos ago its dual 2ohm at 800watts rms, this is a beast internet price of this is $269, on loca shop you cannot get these lower than $300 my price is $175 firm
this was used in my wife's car powered 4 ohm at 600w, this was never abused (my wife mostly played slow love songs)
This is the newest model the older model has a silver cone and only runs on 600watts rms, this is a better sub overall
specs
•Power Handling:
Peak: 1600 watts
RMS: 800 watts
•Impedance: Dual 2 ohm
•High Excursion TPE (Thermo-Plastic Elastomer) surround
•VAST Santoprene surround increases speakers effective cone area improving performance
•Kevlar fiber reinforced semi-pressed paper cone
•Proprietary spider cooling vents
•Ultra-High temp aluminum voice coil with laced Nomex insulating reinforcement collar
•IDHS (Inductive Damping Heat Sink) for heat dissipation
•Optimized motor magnetics with extended vented pole and bumped backplate
•Parabolic triangular cone geometry support system
•Precision cast and vented aluminum alloy basket
•Dual opposing spiders improve mechanical stability under high excursion
•High-temp and high-strength neck joint bonding techniques
•Double stack ferrite magnet structure
•Removable and reversible screw concealing ring
•Anodized aluminum voice coil former
•Copper clad aluminum wire
•SWIFT (Selectable Woofer Impedance Fused Termination) connection allows for quick impedance selection using 10 gauge lead-in wire connections
•Compression wiring terminals
•Embedded copper heat sink shorting ring reduces back EMF (Electro-Magnetic Force)
•Rigid die-cast aluminum frame
•Hard anodized aluminum dust cap
•Metal mesh grille included for added protection
•The slot mounted frame design allows for tweaking of the mounting position
•Sensitivity: 86 dB
•CEA-2031 Compliant
need to sell txt me if interested 813-eight42-3250
Local pick up only
what time on Sunday, i have a guy that might buy it but he wont be here in Tampa till Sunday night, so hopefully you get here before then so i can text him that the sub is bought, let me know
naughtyca
naughtyca
Tampa FL
naughtyca
