Rockford P500-1BD - very solid mono amp. Lots of power for cheap.
tyroneshoes
886
NJ
I used this amp as my temporary amp for about 2 months. Would have used it permanently if I didnt go to a 1 amp solution. Condition is excellent as you can see.
My new amp is in and Im cleaning house as I no longer have need for this and need to pay for home repairs. Bought new. Powerful, small, efficient and very heavy. Solid build on these amps. Very underrated as youll see. I like the terminals and the way they look personally. Efficient and never gets hot.
$160 shipped
Description
Punch Series Monoblock Class BD Car Amplifier
RMS Power Rating:
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
1 ohm: 500 watts x 1 chan.
Remote bass level input (remote level control sold separately)
LED power, thermal, and protect indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz or 0-12 dB bass boost at 12 kHz depending on crossover selection)
On-board differential inputs eliminates noise picked up by the signal cable
Mono channel operation
RCA Pass-thru outputs
Featured custom designed TO-247 MOSFETs have 60% more metal tab area providing more power handling capacity, lower impedance and improved heat dissipation over traditional TO-220 MOSFETs found in most competitor's amps.
Built-in NOMAD is a "real time" analog computer that protects your amplifier from shorting speaker wires and dangerously low speaker impedance.
MEHSA3 reduces MOSFET temperatures, lowers distortion, and increases durability
Cast aluminum heatsink evenly distributes excess heat across entire amplifier heatsink
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable low-pass filter (35-250 Hz, 12 dB/octave)
Selectable infrasonic filter (28 Hz, 12dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-250 Hz
Dimensions: 10-1/4"L x 7-5/8"W x 2-1/4"H
More pics here:
http://www.sonicelectronix.com/search_clickout.php?keyword=p500&query_id=7557114&product_id=19556&product_name=Rockford+Fosgate+Punch+P500-1BD
refs
DIYMA.com
No, Im afraid I dont. I never purchased he remote. When I recently moved, the girlfriend thought she was doing me a favor organizing and throwing out boxes (including a box of nos oz matrix tweeters because they were light so she thought they were empty and the box looked old). All I have the amplifier you see there.
Manual:
http://www.rockfordfosgate.com/rftech/library/2010/3_Amplifiers/1230-55966-01_RFPunchMono-MAN.pdf
This sub was only ran at 2 ohms and never pushed. It powered an IDQ 10.
tyroneshoes
tyroneshoes
NJ
tyroneshoes
