Rockford fosgate t2500 at max
What are you setting your gain at? What wires are you using? What subs? What box? What are your listening habits? If you do not own and know how to use a dmm the answer is no.
0/1 and 8 ga, 2 Mayhem 12 D1 –Ascendant Audio 12 ,ported box,listening habits so so turn it up once in while to show off
Its going to be temporary till I get another t2500-1bd
I was told to run it in parrel but I would run parrel if I had two ampOne amp it need to be series
correct, 2 separate amps/strapping = .5 each, . BUT having 1 big *** amp for both woofers, 1ohm, .25ohm, or 4ohm.
edit - just realized i posted in an old thread where the OP had problems with rebel....my bad
dfrancis24
californa,md
d77543020
