Rockford Fosgate R400-4D install help needed
mr.chep
mi
I need some help setting up my new amp, speakers and sub. I purchased a Rockford Fosgate R400-4D amplifier, (4) Rockford Fosgate 6x9 P1694 speakers, and a R2D4-10" 4 ohm Prime Subwoofer. Here are the links to each of them and their specs.
http://www.rockfordfosgate.com/.../r400-4d
http://www.rockfordfosgate.com/.../p1694
http://www.rockfordfosgate.com/.../r2d4-10
I want to connect all (4) 6x9 speakers to the 2 front inputs, and I plan on doing that in parallel wiring. Is that better than series wiring for this setup? I want to bridge the 2 rear inputs and connect it to the subwoofer. The subwoofer has 2 sets of inputs. This is where I'm confused on which way to wire it. Since I bridged the rear channels of the amp, what ohm setup should I be trying to achieve? Here is a pic of the different configurations. Thanks for any help!
View attachment 26554602View attachment 26554603
Should I wire both rear outputs to each side of the dvc subwoofer? Or should I bridge the rear outputs and wire in series for an 8ohm load?
mr.chep
mr.chep
mi
mr.chep
