Rockford fosgate problem
I would check and make sure your ground is in good contact, possibly the rca's could be going bad, maybe on your head unit too. If its your amp then idrk. Good luck any which way. Lmk when you find out.
Bad ground/power connection and/or, insufficient power wire size that was taking out FETs in the amp on at a time until it finally wiped out the last operating transistor.
But pics would be nice to see. Does the power light come on without the amp going into protect?
Carlsoso
Carlsoso
Cincinnati
naughtyca
