Sold Rockford fosgate P6002
dpom
Well my friend was playing his subs and then all of a sudden they cut off and the amp wont turn on. so we thought he blew it but then realized the positive and negative wires were switched going to the speakers. Well we un hooked it and then later hooked it back up and it powers on but the subs arn't hitting at all. ive hooked up my amp and his subs hit fine, so im not sure exactly whats wrong. ive taken the cover off and nothin looks fried but im not an expert. ill get some pics later when i get home, house is currently in the process of a move.
anyone interested?
50 shippedOBO
they were 2 MTX 12" 5500's wired in 2 ohms is what it said on the box, though they wern't mine so im not sure. but we ran them fine on 3 different amps, its just this rockford amp that they wouldn't work anymore with.
ya, and the terminal screws fell out, 1 went into the amp which i removed when i took the cover off and the other i have no idea. still has the other 2 screws tho.
no idea, i just saw it said 2 ohms on the box. when we were hookin it up again, when you touched the speaker wire to the amp, sometime it would spark and the subs would hit. im not sure what that was about but it only did it a few times.
it sounds like you blew the output channels... if the amp will turn on but the sub wont with that rockford, i bet the outputs got jacked up from you or whoever switching the polarity... and a pointer, dont hook up your amps or unhook them without disconnecting your battery... if your sparking the amp trying to hook it up, you might as well sell all your stuff here.
dpom
dpom
Holly Springs, NC
dragnix
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
