Sold Rockford Fosgate P4004 amp, P3001 amp, 2 10" P1's, Random RF wire.
tipnitty
TH^T GUY
Neighbor is sold his truck and now needs to get rid of his audio so i'm helping him out. Everything is in good working order and pretty good cosmetically, some of the amps have a few scratches on them but nothing really major. No birth sheets or orginal boxes included, they were tossed when he moved. Prices are listed next to the item and OBO. Refs are in sig.
1) RF P4004 amp SOLD
2) RF P3001 $90 boxed and shipped
CEA-2006 Compliant
Number of Channels 1
Rated Power
continuous power 150W x 1 @ 4-Ohms RMS
300W x 1 @ 2-Ohms RMS
Total Power
total sum of 'rated power' 300 Watts
Bridgeable No
Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Punch Bass EQ (included with cable)
Visual Indicators Power On
Signal Level
Thermal Status
Speaker protection
Circuit Topology Class Class-bd
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 11.5 Lbs.
(5.2 Kg.)
Dimensions (HxWxL) 2.4 x 11 x 11.7 (in)
6.1 x 27.9 x 29.7 (cm)
3) RF 2 10" P1's $100 + shipping obo
Description Value
Size 10"
Impedance 4-Ohm
Power Handling 150 Watts RMS
300 Watts Max
Voice Coil Diameter 1.5" aluminum
Motor Size 38 oz. single stacked
Speaker Connector Dual 8 AWG compression
SPL (1w/1m) 85 dB
Mounting Depth 5.25 in.
(13.34 cm)
Shipping Weight 9.8 Lbs.
(4.4 Kg.)
4) RF fuse holder No fuse included $7 shipped
5) RF 4 gauge silver wire 33" and 157" run Best offer?
6) RF RCA cable 16ft have 3 sets, 2 are the red wires. Best offer?
7) 2 RF bass booster cable. Have no idea where the knobs themselves are so these are just the cables. Make offer
tipnitty
TH^T GUY
tipnitty
St.louis
RuinedAng3l
